Yes. You could count the teeth on the large sliding gears. Terra's have 45 teeth. If the tcase is out you could check the input turns to output turns. Should be 3.15 input turns to 1 output turn in low range.
Its been a while since I installed my terra low set, but one of the terra low gears has a "B20" stamped on it and the others just a "20" This is because there is one gear that is different in a bronco dana20 that a jeep dana 20
