Idle air screws
gick70
Holley carb,tuning my carb with a vacuum gauge,I,m getting a lot of change with one screw but not so much with the other,what gives? Blockage??
rmk57
Float level to high, blown power valve if it's an older Holley, to much idle transfer slot exposed. Has to be pulling fuel from somewhere.
SHX669
What RMK said --
Which Holley carb ?
Are you turning one screw 1/4 turn at a time then going to the other ?
Seventee
In the sticks of MT
When I've run into this issue, it means the air bleed for that side is plugged. I clear it up by removing the idle screw (keep track of the little seal!), and giving the circuit a few short blasts of compressed air. Then I do the same back through the air bleeds, which are the tiny tubes poking out of the top of the carb.
This isn't to say something else isn't a problem, but it's an easy place to start.
blubuckaroo
Grease Monkey
Ridgefield WA
X2.
Gasoline deposits can build up in the air horn and plug up the air bleeds.
I found a long nylon tube for spraying carb cleaner into tight areas. I pull the air bleed screws, and hose the ports out.
B RON CO
Statesville, NC
Hi, X2, as long as there is no vacuum leak on that side of the plenum, as in a leak at the manifold to head gasket or warped carb base, or something like that. Good luck
