Ignition coil question
75ranger
Hey all-
I have recently installed a new edelbrock intake/carb. I have come to the point to hookup the coil and cannot find a place to mount it. It was on the stock intake before. Where do you guys have yours mounted? I have the stock coil and duraspark but might be springing for a new coil. Any opinions?
broncnaz
Not uncommon to attach them to a valve cover bolt. or even a timing cover bolt.
Airmapper
Foolproofness Tester
Bowling Green, KY
I mounted mine to the inner fender wall using a MSD bracket. It's upright, out of the way, and closer to the wiring so I don't have to run wires out over the engine as bad.
broncnaz
just get whatever coil you like. I use a accel. for the most part you really wont see any differance as the coil only generates the amount of spark required to jump the plug gap. Stock coils are fine in most cases.
WSM29
What intake did you end up with? The Performer 289 should be set-up like your stock intake and allow for it to be mounted to the passenger side stud on the intake.
