Ignition/Solenoid/Coil question
rmfreeze
Benton, Arkansas
Hey guys, I'm wrapping up a Painless wire install and have a question. I'm using a Pertronix distributor and 12v coil. The purple wire in the painless harness comes off the ignition switch and in the engine compartment it "Y's" and one leg goes to the "S" on the solenoid and the other leg goes to the "ignition" section and isn't labeled at all. Initially I thought this should go to the "+" side of the coil. But in thinking this through I don't think that's where this goes.
There's also a blue/white wire in the "ignition section" that says it comes from the fuse panel and goes to the resistor (not using one) or the "+" side of the coil. I am ASSUMING this provides switched power to keep the coil energized when the engine is running. What I don't know is if it provides juice to the coil when the ignition is in the start position also??
If not, do I need a wire from the "I" side of the solenoid to the coil to provide power during the start/crank portion??
Now you see why I am thinking that purple wire leg doesn't go to the "+" side of the coil? If it did, it would feed back during the "run" or "on" position to the "S" side of the solenoid and make it crank in "on" and "start."
Thanks in advance, Robert
EDIT: Sorry, I got all screwed up with what you were saying. It's almost late.
Yes, purple (GM color code) is usually the one to the "S" terminal on the starter relay. but I'm not sure why it would go into the ignition side of the harness. Are you sure it's not a duplicate wire? Centech has two purple ones for some reason and really messes with you.
Only the wire to the "I" terminal would normally feed the coil during start.
Could the one you saw with the "Y" actually be for the "I" terminal? Or is it too clearly marked for that?
Your Blue w/white wire "should" keep energized even during start, but it may depend on where it gets it's power from. Haven't used the Painless kit yet, but usually it's going to have power all the time. Just in case it doesn't for some reason though, would be another good reason to run the appropriate wire to it's home on the starter relay's "I" terminal.
If it indeed has juice to the purple start wire when the key is just in the on position, you should be able to test that easily before hooking it to the relay. Just turn the key on and see if there's juice to the "S" wire. If not, it's probably ok. If it does, then you may have a mis-marked wire, or there is something deeper wrong with your particular harness.
I see your concern and don't know what the exact answer is unless Painless has some other function for that wire.
Triple check to see if there is indeed a Y in that circuit. Just to be sure.
And sorry if you read my pre-edit post. I was mentally deficient at the time.
