ChiefDan
I was busy rewiring the ignition switch today. I got the old female terminals out of the plug, but I couldn't reuse them. I went with some regular crimp type spade plugs and inserted them into the plastic plug. It works, however since they don't latch when you plug the wire plug back into the switch body, the new spade plugs get pushed back up. I remedied this by taking a small screwdriver and pressing the female spade back into the plug. Seemed to work.<br>What I found is a bad ground at the starter solenoid. Not sure what is going on, but if the original ground is connected, can't start. I took it off and ran a ground straight from the battery, and it started. My question is, can I go ahead and give myself a new ground from the battery to the solenoid, or is there a reason the ground comes from somewhere in the truck? I think I am safe, the Hayes schematics just showed a ground, but I look to the wisdom here for verification.<br><br>Thanks<br><br>Dan
