Ignition trouble
Cmaxx252
Bakersfield
Hey guys,
I've finally made it to the point of getting the engine fired up on the run stand. The problem im having is as soon as I turn the key from lock to "run" it will crank over and fire up, but starter will stay engaged. Am I missing something elementary here? I've wired the ignition according to the book for a 94 and earlier 302, with a dura spark II ignition module. Pictures showing current set up.
Ignition key switch is as follows:
Power to "bat" post
Start post to starter solenoid
Acc to fuse panel
Ign to top side of ballast resistor
The two white wires on the starter solenoid are from the start post on the key switch, the other is the white wire to ignition box in pic #3
Red on the top of the ballast resistor is from the "ign" post from key, and red back to the ignition module pic #4
Bottom of ballast resistor is from the starter solenoid, and one to the + side of the coil.
Scratching my head here... Hoping the experts can help point me in the right direction.
Please advise.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Looks like the battery is connected to the wrong post on relay?
The relay should be marked with "S" and "I", and if they are connected backwards, it will not work correctly.
Connect the wires to the stater relay like this.
Connect the Duraspark circuits like this.
Looks like you have DS II module with Blue insulator.
he Black & Green insulator modules connect differently, even though they have the same connectors (thanks Ford).
Cmaxx252
Cmaxx252
Bakersfield
I really appreciate the response. I'll match these diagrams and let you know.
Thanks again.
Cody
Cmaxx252
Cmaxx252
Bakersfield
Making progress.
Wired everything up according to the diagram and she fired up actually.
New issue, starter is staying engaged. I troubleshot where I am getting power to the solenoid even in the run position, and its back feeding through the white wire (blue number 4 terminal on the diagram). With it connected to the run position post on the key, its acting like its back feeding through the module, through the number 5 terminal keeping the starter solenoid energized feeding the starter. Does that make sense? what would cause this issue? a short in the module?
ntsqd
heratic car camper
Upper SoKA
I've had that happen, been monitoring this thread to see if you ran into that or not. I'm told that it's a function of the starter relay, you need the newer version or something.
The way that I dealt with it was to wire the 'start' wire for the IGN module to the starter's high current stud on the relay. Sometimes that works, sometimes just leaving that wire disconnected works. If you opt to try disconnected you'll need to understand that it won't start while you're cranking, it will only start right as you let go.
Cmaxx252
Cmaxx252
Bakersfield
Ive got it hooked up to the "S" post of the starter relay. It was too late last night to fire it up. Im about 30 mins away from trying it.
When you say high current stud, are you meaning the S post, or the bigger terminal feeding the starter power once the solenoid is activated?
ntsqd
heratic car camper
Upper SoKA
Big stud that the cable from the starter is connected to.
BUT, it sounds like you've got it connected wrong. Of the two wires in the two wire connector on the IGN module one is run while starting and the other is run. The run while starting wire should first be tried on the "I" terminal of the starter relay.
Oldtimer
Sunnyvale, CA
On some of the relays the "I" terminal is connected to the "S" terminal internally with a wire, which may allow backfeeding.
The "correct" relays have the "I" terminal connected to an internal contact that only sees 12v when the relay is closed.
I don't think there are any external markings to differentiate between them.
I am aware of this because in a younger life (60 years ago) I took them apart to see how they worked.
ntsqd
heratic car camper
Upper SoKA
I wasn't recalling the details, but that sounds familiar. If the relay will try to start the engine by applying power to the 'I' terminal then it is the wrong type or version.
In the 70's I used to "rebuild" those relays. Usually it was that the disc had worn the contacts on the ends of the high current studs. Flipping the disc and the studs made everything new again. We'd replace the carefully drilled-out rivets with some short 8-32's and nuts.
Cmaxx252
Cmaxx252
Bakersfield
Hi Gents. Hooked it up exactly like the diagram. Starter wants to stay engaged.
With terminal #5 hooked to run power, its back feeding terminal #4 giving the S post 12v.
I unhooked Terminal #4 at the plug so it was not connected to the starter solenoid. Only way it had power running to it was through Wire/terminal #5 with run power, which has to be in the module? That's possible right? as in there is a short in the module between those two.
ntsqd
heratic car camper
Upper SoKA
If you move the "Start" wire from the 'S' terminal to the 'I' terminal, and then try to start it what happens?
Cmaxx252
Cmaxx252
Bakersfield
I ran terminal #4 (white wire from the box) to the fuse panel (12v running).
Terminal #5 (red wire from the box) to the "I" terminal on the starting solenoid.
Start bypass wire from "s" terminal on starting solenoid to the downstream side of resistor (for starting power).
Ran it through one heat cycle so far. Carb needs a rebuild and I have one noisy lifter to diagnose.
Ill pm you guys from the thread. I need to send you something. Youve been very helpful and I appreciate the input.
Oldtimer
Sunnyvale, CA
Does your relay have S and I marked on it?
The 1st photo in your original post appears to have 1 red and 2 white wires connected to the S post.
Cmaxx252
Cmaxx252
Bakersfield
Yes it does have the S and I indicated on it.
I had the wiring wrong in the first set of photos. The large red wire has been removed. Current wiring is show in pictures below.
