77bronco_ed
- Jul 3, 2004
- 1,784
rather than switching out ignition switch I made some jumpers to use the old centech switch. since the original problem was not ignition I can test to see if new switch is bad.
I did have running but as I said I had to exchange ignition switch due to cylinder being stuck in switch which prevented me from installing.
I ran ignition, battery and start wire to old centech ignition switch and I am getting same thing. turns over but no start.
Changed out Ignition Control module it is now new…
Cleaned up plugs for ICU
Going to change the ballast resistor next, this was discussed earlier in thread. (Not likely)
I am wondering if I have yet another loose connection. I had to fix another connection on a store bought ground cable, soldered the end on. and re-installed.
