Ignition trouble shooting
tmorris1076
Got in my 73 yesterday and it would not crank or even barely turn over. Tried jumping it to no avail. Tested battery and it had 100% charge. I then switched out the starter solenoid and it cranked right up. Old solenoid below
When I went to shut off the truck engine kept running. All electrical was off with key in the off position but engine continued to run.
Do you think this is a bad starter solenoid or bad ignition switch? What should I check first?
I appreciate the help,
Tyler
Justafordguy
Pull off the small brown looking wire in your picture and see if it cuts off. If so the new solenoid is bad. If not it's probably the ignition switch but you will need to do some more troubleshooting.
tmorris1076
tmorris1076
Ok. I think that's how I got engine to cut off yesterday. Ill confirm and get back.
broncnaz
Also clean the fender underneath the solenoid it needs to have a good ground point.
