Inline fuel pump
76BroncoTWJ
Owasso, OK
Ok I have decided to scrap the mechanical fuel pump and put in a new low pressure in line fuel pump. I have figured out how to do all the plumbing of the fuel lines, but I do not know how to or where to wire the positive lead from the fuel pump. All help would be appreciated.
70_Steve
Old Guy
85 to ground
86 to the ignition coil (+) or the ignition switch terminal that feeds the coil
87 to the fuel pump (+)
30 to an inertia switch->fuse rated for slightly more than your pump draws->battery (+)
85 and 86 are the coil of the relay. Although those coils don't draw much current, I wouldn't recommend wiring it to the + side of the ignition coil. The power to the coil is already current limited by the resistor wire. I would suggest using the Green w/Red stripe wire (904) which comes off the same connection point on the ignition switch. Find it under the dash at the ignition switch, or look for it under the hood at the voltage regulator.
Definately fuse the power to the pump, and use either an inertia switch or oil pressure safety switch.
76BroncoTWJ
Owasso, OK
ok guys i do appreciate the help, but I am an idiot about this stuff. The web links were an awesome tool for me. I do not understand the numbers. Are they part of the relay and socket or part of the bronco wiring? I am guessing I need to buy a standard 5 pin relay, relay socket, and inertia switch. Will the relay and socket have a diagram of how to wire them? Does only one wire run to the inertia switch? THANKS AGAIN GUYS I DO APPRECIATE IT.
70_Steve
Old Guy
The numbers refer to the pins, or connections, on the relay. Here's a couple pictures that might help. One shows the pins on the bottom of the relay. The others should be self-explanitory. The circuit diagram does not, however, show a fuse and inertia switch/oil pressure safety switch between the battery and the relay pin 30. Since this is to power a fuel pump, these things should be included.
Steve83
Standard relays' pins are numbered that way. Most have their internal wiring diagram molded or printed on the side, showing those numbers. Get one and check it out.
You can connect standard blade-type connectors to the relay without a socket if you prefer, but they should be the insulated type.
There's a power wire going to the inertia switch, and a feed wire coming out. Ford switches have a 3rd terminal that isn't used.
76BroncoTWJ
Owasso, OK
Thank you guys so much that is a tremendous help. I think even I can figure that out. Thanks again. I will let you know how it goes.
