Inner Door Handle Problem
jw0747
San Antonio, TX
When opening driver's door from inside paddle handle is not clearing the arm rest to release door latch mechanism. Installed new door control mechanism and this didn't fix problem. Removing the arm rest allows paddle handle to release door latch and open door. When arm rest installed there isn't enough room for paddle handle to release door latch mechanism. Anyone had this problem?
Sounds like either the rod is not adjusted properly, or there is some flex somewhere that's not allowing linear action.
How does the passenger side work? No problem there? Usually not as much, since they don't often get used as much, but sometimes they have issues of their own as well.
The amount of pull should be very minimal.
I'm trying to remember if the actuating rod is adjustable there or not. Seems like it is.
Memory is flawed, 'cause I was just tweaking around with mine last month to get them to work.
My driver's side was not only hard to pull (very hard!) but took up more travel than was expected. Still worked, but the amount of force made me worried that it would break the lever arm first. They're a well known failure point if things aren't dealt with soon.
How hard is yours to pull?
In my case, lubing everything up cured 80% of the trouble. I don't remember adjusting the rod, but I had them all out at one point too, and put them all back in adjusted the best I could.
Good luck.
Slowleak
Georgia
The rod from the inner paddle handle to the latch is not adjustable but I’m thinking that adjusting the rod from the outer button to the latch will take out the slack. It’s been a while since I messed with mine.
jw0747
jw0747
San Antonio, TX
Good luck.
Good advice, thanks. Passenger door operates properly no problem. I'm going back into the driver's door to determine if the rod is adjustable. If so, shortening it is in order. The end connected to the inner door mechanism was not adjustable. Also going to lube everything really good.
jw0747
jw0747
San Antonio, TX
It’s not. The only adjustment in the whole mechanism is the rod from the outside button to the latch.
Thanks for the info. Looking inside the door it appears that the outside button to the latch rod can adjusted without removing it. True?
Slowleak
Georgia
Yes. You just unsnap the clip and rotate the connector. I’m pretty sure that will fix you up. Just make sure you don’t get it too long and preload the button.
gr8scott
This is exactly how fixed mine.
Klwhite74
Hi there can you tell me what book this diagram is from? I’d like to get a copy if it’s still in print. Thank you
Klwhite74
Awesome thank you
I’m home schooling myself on my ‘77 bronco She may not run all the time but buying this Bronco is one of the best things I’ve ever done !!!
I love trying to figure it out
Klwhite74
I’m so excited I just found the electrical Vol 4 edition on eBay I can’t wait to read it
Thanks again
This forum has been so helpful !
One thing to be careful of when talking about the factory shop manuals. Make sure that the “electrical“ section actually includes wiring diagrams.
Sometimes they had a full book that just showed the layout and location of the wiring harness and components, but without an actual diagram that you could use to diagnose problems in the pathways.
So verify that the pictures inside include wiring diagrams. Not just “Diagrams“ of the layout.
Speedrdr
Legend in my own mind
Paris, MS
I found a CD of the 1977 Ford truck shop manual like @Slowleak showed the cover off. It’s about 2,600 pages long. The bad thing about it is that it covers EVERY Ford truck from bronco to F-450 (maybe even larger) and you have to make sure you look at bronco specific parts. Otherwise, it is comprehensive!!
Randy
