Installing a Magnaflow Exhaust
bostonbronconut
Question Asker
Wayland, MA
I've been struggling to get a Magnaflow exhaust installed on my '77 Bronco (https://www.magnaflow.com/products/15344-magnaflow-1966-1977-ford-bronco-street-series-crossmember-back-performance-exhaust-system). I think the culprit might be that my long tube headers sit too low and I can't get the cross member to fit around the transmission correctly. As you can see in the photos, I had to use a flex pipe and adapters to get the cross member to fit, but it wasn't sitting correctly. I've tried using some s-pipe adapters to get the cross member higher but that didn't work.
Before I called a shop, I figured I'd check with the forum to see if anyone else went through the same thing and if I would need to use different headers, which might cost less than bringing the Bronco to a shop, or if it is something else. I can provide more photos if it is helpful. Thank you, as always.
White Knight
I have long tube headers and installed and did duals…. Ended up with custom routing but may help
Shimmy
1977 Bronco
Maple Valley
I have the James Duff dual setup with TBP long headers, zero fitment issues. What brand headers do you have? If you want to keep the long headers, i think taking it to a shop and having them rebend that section is your solution. I'd personally do that vs swapping headers.
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I'm not 100% sure since they were installed by the previous owner, but if I had to guess, they are the Scott Drake long tubes. The tube layout/routing looks the same, and they come with a three-bolt flange.
I'd love to bring it to a shop and have it installed the right way, but I don't have all of the pieces secure, and I can't get the downturn pipes properly connected to the mufflers. I assume the drive wouldn't be too loud or risky as long as everything was fastened correctly for the 3-mile drive.
jcpetrson
What did you end up doing. I've got the TBP long headers and about to order the exhaust?
bostonbronconut
bostonbronconut
Question Asker
Wayland, MA
I figured I would do an update. I brought the Bronco to a shop down the street and they had to cut off some of the x-pipe and welded it to a 45° and a flange to make it sit correctly. It purrs now.
