Installing a US Shift Controller
rcmbronc
Tomah WI
Getting ready to install my US Shift 4R70W controller. Pretty sure I am going to mount it in the glove box. I have the EFI computer right behind it.
Does anyone have a diagram again of the wire location going into the EFI computer that can can look at to determine the ground, power and TPS input wires to tap into the controller?
Also where do most people rout the wire from the controller to the tranny. A hole in the dash or what?
Viperwolf1
electron whisperer
Depends on what computer you're using. Also RJM harness has a connector for trans controller.
rcmbronc
rcmbronc
Tomah WI
I am not completely sure. It is a A9 for an Auto tranny. It is also a stock harness reworked.
Viperwolf1
electron whisperer
Pin 40 or 60 for ground. Pin 37 or 57 for switched power. Pin 47 is throttle position.
