I have a 1968 302 that I plan to rebuild and install in my 69 Bronco project. It will be a mild build; stock pistons with new rings, mild hydraulic flat tappet cam, etc.
I sourced a pair of inexpensive GT40P heads a few years ago; they have a broken exhaust manifold stud or two that I'll need to remove, hence the low price of $100 for the pair.
I'll disassemble them, clean them up, check the valve job and touch it up if necessary. I'll also magnaflux them; I have a yoke and powder. And I'll check the deck for straightness and surface them if necessary.
From what I can tell, compression ratio should be somewhere around 9.3:1, which is perfect.
Any other issues to be concerned with? I know I may run into issues with headers and/or spark plug wires.
What about the springs? They should be fine, right? 110 on the seat and 310 open should work with a mild hydraulic cam.
Thanks,
Scott
Thanks,
Scott
