Installing Fuel Pump Eccentric
stanz
Portland
Really basic question but I’ve never had to deal with this before...
I’m about to install a 2 piece fuel pump eccentric on a roller motor. I picked up Comp Cams kit, it’s got the bolt hole and a tab to hold it in place. Does the tab go into the dowel hole for the cam? I assume it does but want to be sure as I am surprised that I cannot find the answer online.
The tab is slightly smaller than the dowel hole. I assume that is ok?
B RON CO
Statesville, NC
Hi, yes you are correct. I use blue locktite and torque it to specs on that one. Don't forget to give the new chain plenty of oil before you put the cover on. Good luck
stanz
stanz
Portland
Thanks! Is oil better than assembly lube for the chain?
