- Mar 20, 2008
- 1,249
Alright, My pea brain is confused. I need to install my new grille trim.
I see that the way to mount the plastic clips to the grille is to place the pin in the holes in the grille, and push the plastic center pin (from front to the rear). This secures the clip to the grill. Easy enough.
Now I see, on the back side of the SS trim, there are notches in the trim so you can insert plastic clip into the trim and slide the clip into position of the grille holes.
O.K. so ya slide the clip over to the hole lining up the pin, buts ya can't push the center pin into the hole cause the trim is covering the pin! What am I missig? the chicken or the egg????
