I bought the grille trim clip set from JBG, but I cannot figure out what the procedure is to install the trim. The clips with the nuts on the back are easy as I can slide those into the trim, line up with the holes, drop into the proper holes and add the nuts after.
What I can't figure out is the plastic clips with the round plastic piece you push through the clip to lock into the hole in the grille. If I slide these into the trim first I won't be able to get the round piece in after. If I slide the round piece in first then will the clip fit the hole in the grille? Should I install them into the grille first - if so, how do I get the trim on to the clips? Will the trim snap over the clips (without chipping my fresh paint)?
I am sure there is a simple answer, but I am clearly to tired to figure it out myself
