Instrument cluster gauges
bronco121
Spokane
Maybe someone has had this same problem. My fuel, oil and temp gauges just stopped working during a drive. Pegged all the way to the right. Everything works except these 3 things. Cluster is all stock. Switched out the small instrument cluster regulator just in case, no change. Any ideas would be appreciated, thx.
oleguy74
calif city ca
lost ground to cluster?easy way to test is to dics temp sender wire connect volt meter to lead from gauge and see if you have a pulsing voltage from 4-6 volts.O turn key to accessory.
B
bronco121
Spokane
Just put new VR on back of cluster, still the same thing, gauges all the way right. Still checking for ground issue.
B
bronco121
Spokane
Ok, replaced my new instrument VR with new one from Tom's, now the gauges are fluctuating, pegging to the right for a second then returning to normal. Seems like cluster and all wires are good behind dash. Not sure what to check next
Viperwolf1
electron whisperer
Add a ground wire from the IVR mounting screw to a spot on the firewall.
