first timer
- Dec 17, 2008
- 53
I believe my cluster isn't grounding at all times because my gauges will either work or not. I know it grounds through the screws and the ivr grounds to the cluster. I have a bc broncos dash with the grounding studs.
Question is where could I run grounds from the cluster to dash? Would it need to be at all 4 mounting screws and ivr? or could I get away with one screw and ivr?
thanks
thanks
