The rear coolant ports are there for emissions. I have seen them used for EGR coolers, which makes sense since it is tapping off the cooler water before it goes through the heads.
There were never any 14 bolt intakes. 12 bolt is the standard small block intake, except some early 351 engines that added an extra bolt at each corner (2 bolts per water passage instead of just 1 bolt).
It looks like the threads may be missing from the rear ports (and why you may think they are bolt holes). In that case you are probably looking at someone who stripped the water passage block off holes (removed iron plugs in an aluminum intake that had water in them), possibly trying to fix a leak. Instead of drilling the holes out to the next size and tapping a size up on the pipe thread and using a proper aluminum pipe plug (probably didn't have the right size drill, the pipe tap, or the aluminum plug) it was way cheaper and easier to just put in a load of epoxy and call it good.
As for the vintage "Shelby" intake, it was the same as the "Cobra" and the "Ford" intakes of the day. They were all made by Holman Moody and the name was speced out by the client buying them. Several years ago I had a great time hanging out will Lee Holman and the stories he had.
