My engine rebuilder installed the aluminum Edelbrock Performer manifold on to the cast iron 302 and aluminum AFR heads. The rebuilder and I were attempting to do the engine break in and ran into challenges. The distributor appears to be off a spline - not continuing to run, the fuel pump's discharge fitting wouldn't seal, and coolant was dripping out of the intake manifold to the front of the engine block just behind the distributor. A small amount of coolant was running down the engine front. A friend suggesting testing the torque on the intake manifold bolts. Am I best off pulling the manifold and sealing it myself? How common is it for a newly installed intake manifold to leak? How common is it for coolant to get into the intakes or cylinders? I haven't written a suicide note yet, just hoping to work my way through what I hope are the final challenges to getting back on the road. Thanks for your suggestions, John B
