Intake Stuck
tk1218
Flower Mound
Taking the intake off to clean and repaint.
Have all the screws out and it will not budge. Any suggestions on how to get it un-stuck?
Prybar down the carb opening and turn it over.
Just double check all the screws are out.
nj_thusar
Asbury Park, NJ
I'm assuming that your doing this while the engine is mounted? I did the same, cut up my knuckles bad, its hard to get off, but I did the same as suggested. Came loose.
Pa PITT
Stephenville TEXAS
Count The Bolts
Some one on here can tell you how may bolts there are in the intake ...or I GUESS you can count the holes in the intake ...If their dirty I HAVE FOUND SOME AFTER 30 min. of work...
tk1218
tk1218
Flower Mound
Got it off, just required patience, which I am short on.
Got it cleaned up and repainted, looks good.
