Interesting Electrical stuff
csangster
I have a Centech harness on my rig. The harness is a thing of beauty.
But I have had a few intermittent problems that I was hoping another early bronco person could help explain.
My heater doesn't always turn on when it is frigid cold outside in the morning; I'll drive a little ways, or slam the door hard and it starts up.....hi and lo speed work fine.
It has become a nuisance and I planned to troubleshoot this weekend.
Things became more interesting today when I was driving to work, fan still wouldn't turn on, and I noticed my turn signals wouldn't work. Fuse was fine, hazards worked fine, but the turn signal wouldn't turn on. I slammed the door because I was a bit frustrated....and what do you know, the heater turned on and the turn signal started to work.
I already called Centech, there is no commonality in the circuit between the turn signal and the heater......so I am guessing it was a wierd coincidence but in my line of work, things are hardly ever coincidences.......
Has anyone EVER had something wierd like this happen?
Please advise,
Chris
p.s. It makes no sense to me why the turn signal and heater are inter-related, but I've heard of wierder things happening.....
302BRONC
i'm no trained electrician, but in my experience on my bronco, my first line of attack would be checking my grounds.
tasker
all knowing of nothing
NH
the heater may just have a "dead spot" on the windings. It may just take a little coaxing after sitting in the cold. Just a guess though.
needabronco
Prescott/Farmington
I would check grounds, and look to see if you might have pinched the harness somewhere when you installed it. Has this happened ever since the new harness was in or did it just start?
brixter
Tuolumne CA
It could also be the switch , mine had problems like that until it just shattered when I pulled the knob out .
C
csangster
Electrical ?
It just started. The harness has worked flawlessly up to this point.
1975SPORT
Hood River, Oregon
grounds have always been my problem...
actually, the last time i broke down on the trail my bronco died and wouldnt start again, turned out to be the starter power cable had fell off, off the subject I know but was a pain in the ass.
JoeBronc74
FAYETTEVILLE
Sounds like your heater blower motor is going south, you can tap them with a hammer/slam your door and it will work a dozen times,then one day she just won't run. as for the turn signals ? uh....uh..? check the ground to the blower motor too, but realy sounds like it shipping the bed on you. good luck.
Pa PITT
Stephenville TEXAS
I too say ground but ..like several have said knock hell out of the blower motor with BFH... SURE is an odd but good time for the chevy upgrade..
C
csangster
Upgrade
What is the chevy upgrade?
I was considering putting in a Heatercraft heater from Complete Offroad.
Other options?
Please advise,
Chris
C
csangster
Definitely not a coincidence, this just happened to me again this morning. Heater didn't work and neither did my turn signals.........slammed the door and voila.....everything works.
Sounds like a grounding problem.....I should investigate.
Any idea where to start?
70_Steve
Old Guy
Negative battery cable should bolt to the engine block. Run (or verify) a ground strap from the engine block to the body someplace. I found a bolt hole at the rear of my intake manifold and ran a strap to the firewall. If you are installing a new strap, be sure to remove the paint from the firewall so the strap makes good electrical contact, and use a star washer. Do the same thing from the engine block to the frame.
SeaBiscuit68
Tacoma Wa
Could also be a bad connection. Wiggle the wires and see if the heater then comes on. Do you see any of those cheesy auto parts store crimpon connectors in there?
C
csangster
harness
Definitely no cheesy connectors in this harness. It is a Centech harness and I installed it myself.
A few recent revelations:
I called the Centech tech center (Centech ROCKS by the way) and they felt that the accessory portion of my ingition switch was going bad because it is definitely not a coincidence that the heater and turn signals don't work at the same time, they are both fed power from the accessory portion of the ignition switch. They said the next time this happens to try and turn on my windshield wipers (also fed off of accessory power). It happened this morning, and what do you know, the windshield wipers didn't work either.
I fiddled with the ignition switch behind the dash a bit and voila, everything worked (and I didn't even have to slam my door hard).
I couldn't speak more highly of the people at Centech, I bought this harness 3 years ago, and they still provide EXCELLENT customer service. If anyone is on the fence about which harness to get, I would say Centech....their service far exceeds expectations.
I'll let you know how the final fix ends up.
Thanks,
Chris
