Interesting Electrical Trouble
broncaholic
Hey all. Long time no talk. I have an interesting electrical issue. When I run my motor into high revs, when shifting gears, allowing the motor rpm's to drop, the headlights dim and damn near go out all the way depending on how high I rev the motor. When driving normal, shifting at about 2200 rpm, no trouble is noticed. I am running a 92 MK VII regulator with my 92 MK VII motor, and a yellow top battery. I have checked my battery leads, motor to chasis ground, chasis to body ground and motor to body ground and they all are good. Any suggestions? Voltage reg.? Alternator?
Thanks!
70_Steve
Old Guy
Thanks!
Just kinda thinking out loud here, but... The power in the system really should come from the battery. The alternator just keeps the battery charged. Loosing the alternator shouldn't result in a dramatic loss of power. It would be noticed as a gradual dimming of lights etc.
The stock Bronco harness powers the entire vehicle, including headlights, through the fusable link. One end of the fusable link is connected to the BAT+ side of the solenoid. The other is the begining of the "loop" (Wires 38 and 37) which goes inside to power everything, passes through the ammeter and comes back into the engine compartment and terminates at the output of the alternator. Dunno what alternator a 92 MKVII uses, but if it's a 3G, or any alternator that puts out more than the stock 60 amps, it's output is probably (should be) connected directly to BAT+.
I'm leaning more to a wiring issue around that fusable link.
B
broncaholic
Yes. I am currently using a 110? amp alternator and it is directly hooked up to the battery. I am also using the ammeter circuit in parallel. I know the ammeter is not reading correctly but did not want to abandon the circuit. I will look into the fusible link. Thanks for the idea.
