I have an electrical issue that I thought was a ground but now I have no idea. I replaced the battery, alternator, and fuse regulator and the truck was running great. I noticed that the eye terminal connector that grounded to the frame was broken. When I would pull that eye terminal away from the frame I would get no power. When I touched it to the frame I would get power.
So I went and purchased all new battery and ground cables. I've been testing the ground side connections by taking a multi-meter and measuring the voltage at the battery terminals (12.76v) then I take the negative on the multi-meter and see if I get the same reading at the engine block, the body, then the frame. I am getting 12.75v-12.76v all the way down to the frame. I cleaned the connections, I wire wheeled the grounding points. This thing is definitely ground...
I gave up last night because I was pulling my hair out after about hour 6 of this chase... I walked out to the garage this morning and boom... lights work, starts right up, no issues. Well then I walked in the house to take a phone call. When I came back out the damn thing is completely dead again. Its acting like the system isn't grounded. No lights, no brake lights, no turn signals, no horn, no start, nothing.
Could this be the starter relay not being ground to the body? Or perhaps the fuselink that comes off the starter relay? Any insight would be greatly appreciated. Thanks
