Is 80 amps too many??? (Headlights)
RODRIG3911
RODRIG3911
Tucson
No problem. I liked the way mine came out.... At first the left side was brighter then the right and I got a little frustrated trying to figure out why. Turns out that my ground on the right side wasn't good enough. Make sure you ground both sides very well ;)
Tulsa76bronco
Rod Got them in where did u run the line? Ran mine at bottom of grill? Where did u plug the blue lights into. What are they for
RODRIG3911
RODRIG3911
Tucson
Ran mine across the inside of the grill too and zip tied it in place... i tapped the wires for the blue lights into my turn signal lights... That way when i turn my turn signals on they flash for the direction I'm going..... it also allows you to turn the blue lights on when you turn on the quarter lights. I think the connectors i used are called T Taps. They made the connections look clean and are super easy to work with...... Let me know how yours turns out :)
Tulsa76bronco
Rod my qt lights don't come on should they be on when the headlights turn on?
Also I have a green and brown wire from the blinker light. Do I connect the red wire from the blue light into it an the black to ground or black to the brown blinker wire?
Now that I disconnected the old lights my wiper fluid doesn't come on, no power I do have a ground wire from the old light harness hanging around maybe I should connect that again
RODRIG3911
RODRIG3911
Tucson
The black wires are grounds and make sure they are grounded very well! I didn't have mine grounded good and first and my drivers side light was dim. I re-did the grounds right and I had no problem.... If your bronco was wired right to begin with all you do is connect the blue lights (In parallel) to the turn signal lights. the T-pas I mentioned are great. Just crimp the blue part that ties into the wire on each of the turn signal wires. Then connect the two flat connectors on the end of the little blue light wires. Then all you do is simply plug the ends of the blue light wire connectors into the T-taps of the turn signals..... Your quarter lights should then turn on the blue lights and the blue lights should also flash with the turn signal switch. If you lived closer i'd go wire it for you, but I am sure you can figure it out too if you look at it.. I'll look for some instructions for a different kit that maybe can help you
RODRIG3911
RODRIG3911
Tucson
These all helped me bro When I was doing mine
RODRIG3911
RODRIG3911
Tucson
Hey I just re-read your post... Black wire from the blue light will go to the brown wire from your turn signal light. You don't ground either blue light wire! They nrrd to both be connected to your turn signal lights bro..... That IS the problem with the quarter nights.... And this goes without saying but i'll tell you any ways. DON"T CUT OR DISCONNECT the origal wires to your turn signals. You are just tying in to the (Connecting them parallel)
Tulsa76bronco
Ha ha thanks rod that's what I was wondering was a little confused on ur other post as I have the head lights working. I don't think my qt lights are working not sure if I ever noticed them working. Should they always be on when my headlights are on. If u get a chance call me 918-630-1647. jeff
RODRIG3911
RODRIG3911
Tucson
I think they should Jeff. Mine do, but I have an after market Painless wiring harness so it might be different. I'll give you a call if I get a chance later. It's my fiancé birthday and I have a short window of opportunity to fix my track bar mount before I have to give her my attention :)
Tulsa76bronco
So o noticed my passenger side qt lights work when lights are on but the driver side doesn't. Well if there both not working prob a wire issue:cry:
