Is the tilt column necessary?
Dne007
Hi, I've been looking at tilt columns and just wanting to ask is it absolutely necessary? Would a standard column work just fine? I have power steering and I remember it being very easy to steer(for the 10' that I moved it). I think I'd be running a 14" steering wheel, or possibly 13.5"? don't need leverage like from a 15".
thanks,
dne'
gclauson
I think it depends...
1. Seat height
2. Driver's belly girth :)
3. Combine those two with where your seat is front-back
You need to be able to get in/out and also drive comfortably without the wheel hitting your thighs or stomach.
In my case, I have a 14" wheel, non-tilt, seats that are about 1-2" higher than stock, and fairly thin build, so I have not needed tilt, but as I get older, a tilt may become necessary!
gnpenning
Bronco Slave
Do you have tilt in any of your other vehicles? After the intial setting how far off is it from a standard column?
Do you remember how the stock column felt?
Even when I was young and skinny I never liked the location of a fixed column. I've changed a few vehicles to tilt. My 74 I did a telescopic tilt. Most would not like it, I love it.
One of my square bodies is waiting for me to tighten the tilt knuckle. Have most the tools in the cart ready to go. This is a common issue with them. A little red loctite on the pivot bolts and you are good.
Everyone is different and so are their tastes. The main person to drive it most, should do what works for them. Make yourself happy, I know I'll be happy for you.
Shimmy
1977 Bronco
Maple Valley
i don't have tilt steering and don't see a need for it. totally subjective
billh1289
Jackson, NJ
I never felt the need to put a tilt in any of my broncos, but it depends on your set up and what you find comfortable. Stock column and stock wheel has worked for me with stock seats. I put seats out of a mid 80’s mustang in my last bronco and it made getting in and out annoying so I ran a smaller steering wheel. In a new build I would consider the tilt though.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
No Early Bronco ever came with a tilt column from the factory, so no, it's not necessary at all. A vast majority still on the road I would bet are still running stock columns.
The type of column has no influence on how easy it is to steer. This is changed by power versus manual steering, type of pump & ram used with PS, diameter of your steering wheel, and what size tires you're running.
ssray
South Central NE
One factor I can imagine coming into play would be trips. A long cross country trip may benefit from adjustability while local close to home runs would be fine without it. Having adjustable armrests can help as well but I’m not sure if many have gone there.
Glass Pony
Sussex County Delaware
1. Seat height
#2 is why I have a tilt column.🥓🌭🍔🍟🍕🍰🍩
Yeller
Rogers County Oklahoma
I ran without for a long time, actually spaced the mount down to accommodate my lowered seats. Ultimately went with tilt to lower it more so my wife could look over it and I have to be different… I moved the ignition to the column, was tired of fighting the crappy aftermarket ignition switches. So completely your call.
.94 OR
Willamette Valley, OR
I fabbed a tilt column in from a T-bird. I have a 13" wheel with PS. At 6'5" it was just easier for me to get my legs in and out and be comfortable rattling around in it in the woods. I like having the wheel tipped away from me which helps turning the wheel quickly with one hand.
Dne007
Dne007
Wow, thank you for the responses!!! hm, guess I'll go with the tilt, just get it over with!
dne'
abn373
Charleston, SC
Keep the OEM size wheel. Or very close. No less than 15" for sure. Those tiny 13"-15" wheels will mess up your perceived handling. it's not about the effort to turn the wheel.
Yeller
I will agree but politely argue, what is perfect for you may be terrible to others. Most say I’m out of my mind but I like 70’s 1 finger power steering with a 3 turn box and a 13-1/2” - 14” wheel and would do a 2 turn if I could get it. While others feel it’s twitchy and out of control, they want a 6 turn box and a 15” - 16” wheel, to me that feels like it wanders all over the road because you have to move the wheel so far to make adjustments. Not to mention arms are tired from spinning that thing all day. It’s all in perspective of the person driving and what makes you comfortable.
Pa PITT
Stephenville TEXAS
OK Let me have my Stab at this subject.
My Bronco has a 2 inch chassis lift & A 1 inch body lift. I'm 5'7'' or I used to be. & iT' Ain't my Gerth It's my BELLY at 250lb now .. That get into my way.
...... SO Yes I want the tilt wheel. ... No My P/S pump was rebuilt & It's the 3.33 turn to 1 . very fast. I hated this at 1st, But after 6 months I love it now & Never feel it.
Now for my Tilt wheels ... I TOOK a column from a 1978 & 1979 F100 /350. ... My Bronco has a NP435 Manual . I couldn't find a Manual tilt so I took an Automatic column & cut off the auto shift lever & Patched it smooth & a coat of paint ... Looks like a std column .
.....Now the 2 problems have been .. I break that RACK that helps tilt it up & down.... I've broke it 3 times & It's broke again. I've just learned to live with it .. It's really still holding in place this time . I've bought 3 more columns through the years .
..... Now the biggest problem with my column is .... The Steering wheel will drop down completely between your knees .. But it really needs to lift up 6 or 8 click ... Not the one or two click it'll go up. I'd like for it to go almost to the windshield NOT TO DRIVE BUT to get IN & OUT .
.... I keep thinking that rack might could be swapped around to let the run be on top not the bottom.
......There are write ups on here that tell you how to rewire the steering column plug from the
79 F100 TO OUR BRONCOS by the year models .
............By the Way ..When you get into your Bronco don't pull yourself up with the Steering Wheel .
ssray
South Central NE
Just rotate that sucker 180 and that might cure it. You just have to get used to the turn signal on the right side. ;)
I had my 87 Regal Turbo T come apart for reasons similar to yours though kinda opposite. I’m 6’ 3” and it takes dropping down to get in it. I’d grab the wheel for support. When it started getting loose I quit that but eventually it let loose. I tore it apart and was lucky in that it the pivot screws had all come loose and let it free fall. Back in with some locktite and it was good as new. Kind of a pain to work on though!
duffymahoney
I am a fairly normal sized guy, 5'11 and 180 pounds. Not small, not big, I have never once tilted my tilt column:)
No tilt collumn for me I am 5'3" and use rebuilt stock seats. I am fairly short and its all in the legs. but what I do need is a shorter column maybe 2-3" shorter. to get my feet in the right place i am sitting too close to the steering wheel. So its not only a big guy problem. use to be worse when I was obese. no longer fat but the wheel is still too close. I have lived with it for almost 45 years so i doubt it will change anytime soon.
Kind of the same here. I’m doing it anyway because I like the option and I’ve gotten used to it in all of the newer vehicles I’ve owned.
However I also drove around in a bronco with a stock column and stock size steering wheel and never had a major problem. I always thought tilt would be helpful, but it was never a requirement.
In my case I always had the seat moved all the way back though, so maybe that makes a difference. And when I installed new seats I moved them even further back.
