englewoodcowboy
Lick Creek Restorations
- Jul 25, 2010
- 4,200
The confusing part you will experience along the building process is there are a lot of things that will "work" but the issue lies if they will work well. .060 bore makes the walls very thin so heat soaking becomes a big issue as others have stated. This follows all of the Windsor engines until you get into the he aftermarket blocks etc. that you will find some that are reinforced and prepped for larger over bores for displacement gains which are pretty much race only.
