- Joined
- May 28, 2013
- Messages
- 1,844
Installed a new BC sending unit in an older BC 23 Gal tank. On first fill up the gauge took 10 minutes to slowly greep up to full. Gauge moved down as I went through the tank but when it registered empty, I was still able to go another 75 miles.
The stock tank and sending unit worked fine.
As a test, I intercepted the wires (ground/hot) near the tank and hooked up my old sending unit and it registers correctly and responded quickly to empty/half/full.
I was able to reach in and ground the new sending unit and it jumped up to full right away.
Before I pull the tank, is there any other test I can do or should I just fill it up again and hope it registers correctly on the next fill up?
Thanks,
Thanks,
