I also have a JB twin stick for a J shift that I want to install in my 75 that also has the boot on top of the case. Is it possible to install the shifters and cut the flags while the case is still in the Bronco without a body lift and without cutting an access panel? Thanks
I thought I seen a thread on doing this when researching this,
Maybe with two people to instal one under and one in the cab, for cutting the flags, you may be able to fit a small die grinder with a small cutting wheel disc,
get the boot off in the cab and have a look
good luck
there should be some others that have been down this road, hopefully they chime in
