Just cut the rear quarters!
josimps2
Just cut the rear quarter panels w/ a cut off wheel. I had an old set of Duff's fiberglass flares that I measured with. I tried to center them over the wheel as best I could, drew a line, and then cut about 1.5" below that line. How's it look? I'm thinking against puttin the fiberglass ones on. I don't have any welting and I'd like to get some ones that are a bit more flexible.
josimps2
josimps2
MikeEB said:
Cut looks good, now you need some bigger meats ;D .
I've got ahold of some 33x12.50's for free, but I'm in need of some rims. I thought I had tracked down some slotted mags, but that fell through. Rather than investing in anything nice I'll probably ended up going w/ some dirt cheap 15x8 black steel wheels. A new set of nice wheels will probably end up costing more than I paid for the truck, so I can't justify a set of MT Classic II's. ;D
josimps2
josimps2
Just put these on a few days ago. It's stock suspension w/ the rears cut and the fronts trimmed. 33x12.50R15 old school Wrangler R/T on slotted mags that I got from Tom Carper just recently. I think they turned out ok. I'll try and get a better pic w/ some sunlight tomorrow. Don't know where I should dump more money next... body, roll cage, or engine?
kntr
I love the old style mags. Post a better pic when ya can. Looks good.
gasspaser
St Petersburg FL
just my .02 but if she runs fine then go with a cage first...then work on engine mods if needed....nice cut...rims aren't bad either...
bigmuddy
Marthasville Missouri
I hate to tell you but you shouldn't have centered them over the wheel well. If you run a much bigger tire, the tire will rub when you stuff it on the rear edge if memory serves. Common mistake, actually did it twice before realizing what I did 8-( Most people start on the gas tank filler side and center there because it obviously looks better than uncentered. Looks like a great bronco!
Ben
josimps2
josimps2
Ben
I guess I read wrong. I read a couple of posts here that stated that there should be a even amount of sheet metal cut on both sides of the tire. I think I also read not cut based off the gas caps. Could be wrong though. I'm not too worried though because the body is pretty shot.
