orange69
- Feb 10, 2002
- 309
Ok guys, I'm getting desperate for some help. I keep burning ignition coils. Here's some specs:
351W, Crane Cams XR-1 electronic ignition, stock coil, 3G alt.
I have replaced the resistor wire, tested voltage (7 volts) thought everything was good then smoked a coil. Installed a ballast resistor, tested voltage (7 volts) then cooked another coil! I've tested the running/charging voltage at battery and it's around 14.5-7. I thought that seemed a little high so I had it tested at NAPA and they say its fine. Talked to a mechanic and he said to make sure all your grounds are good. So I cleaned all the grounds going to engine. Battery cables are clean and look good. I put in a new ignition switch a while ago. Replaced wiring from starting solenoid to ign switch and to coil. I have one wire running from solenoid to coil (for 12v on startup), then another from ignition switch (using existing resistor wire) to ballast resister then to coil +. Yes I'm using both resistor's now.
So on first startup, electric choke works fine (it's also hooked to starter solenoid where the coil is hooked to, been this way for years) so it idles around 1100 rpm. Voltage at coil reads 7.5. After it warms up I bump the throttle and it idols around 650-700 rpm. Check voltage again and it starts climbing to 8, then 8.5 then 9 then 9.9 so I turn engine off. So I disconnect the alternator and try again. Voltage at coil is 6.5. I let it run for a while and it starts to run a little ruff. A quick bump of throttle and it stumbles a little. After its good and warm I check voltage and it goes up to 7. Hook up alternator and it runs smoothly again. Voltage at coil is over 9 volts now. So is my alternator putting out too much voltage when it gets warmed up?
I've double checked the Crane Cams XR-1 electronic ignition and it does require resisted voltage. It hooks directly to coil + and -. It's been on for several years with no issues. I have not tested the spark plugs wires. They're several years old, but it runs great. The coil is just a stock replacement from local auto parts store that requires resisted voltage. I also have a tach hooked to it, not sure if that could cause any issues.
I'm at a loss at this point. Not sure what to try. A new alternator, new ignition system? Sorry for the long post.
