Keyed 12 Volt for Electronic Ignition
73Russell
Federal Way, WA
Anywhere where I can tap in for 12 Volts or should I just run a new wire from solenoid. Points system was 3 Volts, do I keep this hooked up?
broncnaz
If you have the stock wiring and your not using the small round blue plug sticking out of the firewall next to the throttle bellcrank you can use that for a full 12v switched power source. If not you'll need to run a wire from the ignition switch Since you have the flame thrower coil as well you need to bypass the stock wiring as the flamethrower coils have resistors built in. So basically you cant use the wiring that went to the stock coil.
73Russell
73Russell
Federal Way, WA
I am back oto the points turns out I got a Flame Thower III coil and just the Ignitor and not the Ignitor III. I took out the coil and replaced with the original and the Ignitor wouldn't work. Now got to wait to call vendor on Tuesday.
