Kickback on hot start
Cortez
Running fitech efi with timing control, and a phased rotor. Ran fine for the last year but lately I’m betting kickback on a hot start. Any ideas what contributes to this?
Typically too much advance while cranking. What is the advance set to during start?
Are you sure the timing is still set correctly? Nobody bumped anything?
Speedrdr
Legend in my own mind
Paris, MS
When you say "kickback", are you saying the starter attempts to re-engage?
Randy
Cortez
Cortez
Brand new high torque starter and new battery. The kick back is not a slow crank but pretty violent and almost stops the starter. Then it stutters and takes a long time to catch on. I haven’t touched the timing in over a year, was set at 10 base timing and dropped it down to 8 today to see if that would help but that is on the fitech handheld...no reason to believe the timing has changed but could be the phased rotor might have slipped I guess...could that cause it?
jckkys
I agree with Bronco. The timing during cranking is advanced too far. With a distributor that's easy too fix. I don't know about Fitech but I'm sure they could tell you how to set the timing.
Cortez
Cortez
Thx - I will rest with the timing gun and set the fitech ti match, will see if that helps
Cortez
Cortez
I took off the dist. Cap this morning and my thoughts were confirmed, the adjustable rotor phasing had come undone, the screw had backed out and the rotor had slipped causing more advance than was previously set. I should have checked it before posting this but maybe someone else can benefit from it. Thanks for the responses.
m_m70
Prescott AZ
Glad you found the issue!
Happy you posted what you found regardless of when you found it!
It may help someone with the same problem down the road!!
What it's all about!
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Not to be confused with or when to use Loctite or thread locker blue or red. Maybe use some low strength purple. Or maybe some green torque strip material can sort of prevent that screw from loosening. Or at least give you a tell tell sign that is has.
https://www.henkel-adhesives.com/dz/en/products/industrial-adhesives/threadlockers.html
What is a torque stripe? Sometimes a colorful strip of thin lacquer to a bolt/nut to indicate it has been torqued to the proper value. Once cured, the stripe stays pliable under extreme temperatures and vibrations. ... Torque striping is a secure, visual indication that things are tight and right.
Or some of this. https://bimmertips.com/importance-using-proper-torque-values/
Great idea. Thanks for bringing it up.
We should probably all put a stripe on our harmonic dampers! Just to tell if and when the ring slips.
FordBronc
In that application (high rotational forces and exposed to the elements). Some good old red finger nail polish strip or HD torque strip material should work.
sprdv1
REBEL
good plan and idea brother..
