Killer Bee Bronco STILL NOT STARTING
daduze2
Central IL
I have a new mechanical fuel pump, fuel filter, fuel line, check valve installed, and I by-passed my tank selector switch thinking that may have been it. My Holley T/A 670 cfm carb is a year old, my distributor, coil, wires, and plugs all are 2 years or newer. The Killer Bee was flying totally fine last year.....no problems at all. The winter was hard on her.
Pump is pumping, the sights in the carb show fuel.
I had it started this weekend after cleaning the inside of the distributor even though it looked totally clean on the inside. I drove it around the neighborhood fine and parked it.....sat for about 1 hour and it started back up no problem. Sat for 2 days and now I'm back to square one!!!!!!
Any suggestion would help. I'm at my wits end. I would hate to hand it over to a mechanic but I might just have to because I'm clueless at this point.
Here is a picture of my engine bay....I can post more if need be.
http://classicbroncos.com/photos/showphoto.php/photo/13312/ppuser/19042
I have read and searched the message board to no avail.
Spark, fuel?
Spark is an easy check
You mention you can see the fuel in the sight glass, is the accelerator pump a pumping?
daduze2
daduze2
Central IL
what is the best way to check for spark....I read to have someone turn the key while you hold the coil wire, disconnected from the distributor, close to the engine....is that the safest and a correct way to check for spark???? Can't I buy a light or a sensor to stick on the end to indicate that I am getting spark through the wire.....I'd rather not blow up my bronco.
And where and how do I check for the accelerator pump?
Broncobowsher you have been a help to me in the past and I see your posts all the time helping people.....thank you from me and everyone else on here.
Viperwolf1
electron whisperer
You can pull the coil wire from the distributer and place the end within 1/4 inch of a good ground then crank the engine. You can also use an extra spark plug.
For the accel. pump take off the air cleaner and look down the carb throat while you open the throttle. You should see fuel being squirted down by the butterfly valve. Keep the ignition off when you do this or you could lose your eyebrows.
Flintknapper
Deep East Texas
Verify that you have spark and fuel first.
Then look to see that your choke is working properly.
Spark, fuel and choke should= Start.
Once started, let it warm up and check the timing. Let us know what you find.
Remember to VOTE!
daduze2
daduze2
Central IL
Thanks ViperWolf1....I have a brother that lives in Parker, CO.....wish I could take a road trip down there to see him in the Killer Bee Bronco.
I know my choke is working and I'll have to double check on my accelerator pump but I'm sure its working too.
I'll try those things and get back to you guys. Thanks everyone.....
Viperwolf1
electron whisperer
Glad to help. Nice bronco BTW. It reminds me of the Bumble Bee. After you get it running again please tell me how you tied the windshield frame to the hoop. It's been on my to-do list for a while.
A4x4Junky
South Jersey
So long as you dont hold the plug wire near fuel you shouldnt blow it up. However, I got sick of zapping myself to check and bought a light I plug in.
Anthony
mustangtoby
southwest Colorado
Make sure you are touching the bronco with your body while you have someone crank the engine and you're holding the wire. This way you are sure to get a really good shock. Also have someone video this and post it for all to see! Seriously, don't ground yourself to the truck while you do the spark test, or you will feel it!
joel
spray some Berkable carb cleaner in the carb. If it starts, you know it's a fuel problem. I've gotten to the point that that's the first thing I do on a hard starting engine.
If it was sitting, the float could be stuck. Just 'cause there's fuel in the float bowl doesn't mean it's getting to the venturi.
