..been using modern 10W-30
but should i be using something with more zinc? like the diesel truck oils? could this be causing some noises?
everything still runs out fine, plenty of power.
I'd have to say yes. Based on enough reports of disaster with older engines, I'd stick with high-zinc oils only. Or at least additives that do the same thing. Easier with the oil though, I would think.
And while it's possible the noise could come from some sort of damage, it would be very out of character for the noise to come so noticeably and yet still have power (no flat cam lobes in other words) and smooth running.
Usually it's the cam lobes that suffer the damage from low zinc, not the bearings or chains. The lobes are the most stressed surface in an engine like ours I think.
So I'm still not sure. Just out of my personal experience range. Will wait to hopefully hear something in a video if you're able to do that.
In the meantime, a way to find out if the oil is too thin or zinc an issue, would be to add some STP or Motor Honey to the existing oil to see if the sound changes at all. In other words, not just any oil additive, but one of the super thick "viscosity improver" types.
Usually can't hurt, and an easy way to see if there is anything going on with the oil. Well, easier than pulling a front cover anyway!
