Koenig PTO Winch
Tuck73
Just cleaned 50 years of mud and grease from my winch while the body is being painted. I had no idea it was aluminum and looked this way. (It was also painted in camo.) Where can I get a new drum. Also, does anyone know how to get it to release where it will freely spin? So far, it will only turn half way.
Cooper
Northeast
Hi Tuck, I just stumbled on this on e-bay a couple days ago, I have no idea what the price of a drum would/should be.
https://www.ebay.com/itm/1966-1977-EARLY-FORD-BRONCO-TRUCK-CJ-JEEP-KOENIG-PTO-WINCH-PARTS/164761854127?hash=item265c9260af:g:nY8AAOSwxPRgRmmg
Regarding the binding you describe, it sounds like the worm gear is inhibiting movement, but not really sure what you mean by "it will only turn half way". If you dis-engage the shifter lever on the opposite side from the worm gear and its housing, it is linked to the shifter fork and should release the drum. Don't forget to pull the locking/release pin, it is spring loaded. Then check for movement by turning the PTO drive-shaft. If the grease inside is 50 years old as well, it probably resembles glue at this point and just needs to be re-packed. Also, whoever applied that paint you are cleaning off may have gotten some into the bearings and contact areas around the drum shaft or PTO shaft, binding to turn by hand but the PTO would not notice.
PTO's are cool and well worth getting to work, IMHO.
T
Tuck73
Thanks! I’m going to keep working on it.
testin
Camano island
Hi Tuck ... Try Herm
Tuck73, Try Herm The Overdrive Guy ! He has almost everything for these winches. I have three Koenig winches on all my broncos and he's provided parts for all ...
