Last guy to the party
Ict57
After logic (?) prevailed, I bought a 2000 explorer v8/auto for an easy swap (vs coyote or not-Ford v8)).
Seems this has been the gold standard for a decade. I don’t intend to reinvent the wheel, but curious if there are any better wiring options today? Seems most are still hacking at a 20 year old harness. Curious about experiences with Megasquirt or similar.
The truck will see plenty of light/moderate trails but far from hardcore/rock crawling. Plan to keep it simple, 33” with 2” SL and likely Np205. However it will get driven. I probably put 10k in a year on my 75 bronco with 302/c4. Loved that truck. Finally, my last project was a tube chassis restomod with all new tech and about 200 lbs of wiring and computer BS. So, I’m not too scared of tech and fab.
Any particular reason for the 205 if it's not going to be used hard? Seems the lower gearing of the existing 20 would be an advantage?
I suppose if yours is a J-shift then the difference is not as much, but if it's a T-shift there is definitely the lower gearing to take advantage of when going slow.
And it fits!
Well, thinking about it I guess if you have a 205 already, or a line on an inexpensive one, you can save the money on the t-case adapter. That's something.
Don't remember talk about using non-stock wiring though. I bet it's been done.
The more common swap would, until recently, have been the aftermarket harnesses for the Mustang EFI (like this from us: https://www.wildhorses4x4.com/produ...tion-Harness-86-95-Ford/Bronco_Wiring_Harness) which would be used with a standard Mustang-type computer and a distributor for simpler wiring.
You'd need to use a couple of different sensors, but it's what we used to do.
Keeping the automatic you have the extra cost of a stand-alone trans controller though.
Now that it's getting easier to re-work the Explorer harness (by letting EFI Guy do it) and retain the distributorless ignition setup and control the transmission at the same time, it's getting done a lot more.
You're still re-using the existing Exploder harness, but it's being re-worked and tossing most of the extra unneeded wiring to keep it cleaner looking.
How much "extra" work and stuff needs to be done with an aftermarket like a Megasquirt? Their own computer and a premade harness? Or is there a lot of wiring to customize for each setup?
So not sure which way will be best for you, but can't wait to see which road you go down!
Good luck.
unimogger
Philthadelphia
I've built a mega squirt and harness from the board up, and you aren't saving any time or money by doing so. If you want to run a custom tune, or control other items like launch/boost/rev limiter/etc. then it's nice. Or true sequential EFI with the MS3. But way more than needed to simply run the engine. If anything, maybe a microsquirt, though I'm not sure what they're capable of these days. For sure they have harnesses available to plug any MS unit into a 5.0 but again $$$.
Guess it depends on exactly what your needs are and how deep you're willing to dig into the pocket.
SteveL
Huge chevy guy
Hawthorne ca
Most refer to efi guy for the wiring. Hey paul, if hes using the explorer for the motor and tranny doesn't he still need to buy an adapter for the dana 20 anyway? If the 205 fits without hacking up the frame I'd stick with it. Then theres the option of a doubler if you ever need it.
sprdv1
REBEL
if you gonna do it right, just replace full harness to be safe if there's any questions.
Painless, or look at our vendor Harness like the WH one
I
Ict57
Thanks all
Not sure that mine has any issues....but it’s 20 years old.
Anyway, was mainly curious if everybody is still just fixing the oem ford wiring, sounds like I’ll start there.
As for transfer case, expect I can buy a 205 for half the price of a new adapter for my d20.
904Bronco
San Martin, CA
Thanks all
There is no aftermarket harness for an Explorer set up... I would like to say yet, but they have been out of production for almost 20 years, so if it hasn't been done yet, I don't think it will.
Garry, "EFI Guy" does a great job rehabing a harness, he has done 3 for me. I still do an occasional rewire using 88-93 mustang harness and I like the one WH's sells based on Ryan's "RJM" design, if you want to go to OBDI.
If your 4R70W is a 4wd version, then a 205 should bolt up. I have not done one myself, but others have and have posted about it.
frenchy
like super dave said wild horse has a plug and play harrness for the explorer install. 589.00 but I have heard the guy who reworks the original harness is good also. not sure what he charges and what his leed time is.
frenchy
Sure you want to do that to a 66? Just sayin.
frenchy
garberz
Bronco Influencer
Conejo Valley, Ca.
A new plug n play harness would be for 87-93’ Mustang based SEFI. It’s OBDI. There is no new harness available for the Explorer OBDII SEFI. EFIguy can configure your existing harness and set up your computer, to use the Explorer EFI. The Mustang parts are getting harder to find, and what’s available online seems to be getting very expensive.
Mark
I
Ict57
Would prefer to keep obd2 connection, etc and hoping to get efi guy to help out. Have a request out to him!
As for the 66, it’s a u13...and not getting a v8 swap. I should be working on it, frame off is my next project. Instead I’m putting together a truck I can enjoy daily.
Driving a 6 cylinder truck with a bench seat, no seatbelts sans doors is a pretty scary place to be when you’re trying to get up to top speed of 62 mph to keep up with traffic. Inversely, a semi proper truck feels fine in traffic. Dragged home a slightly used explorer to sacrifice tonight.
