This is a broken leaf spring pack center bolt. This is what happens when you don't keep the spring-to-axle U-bolts torqued! Not only that, but the head sheared off low enough that it dropped into the centering hole. Then the 6 degree shim was able to walk out and disappear!
I spent my last Sunday afternoon replacing the bolt and the shim. I won't be making the mistake of not torquing the U-bolts again, which is the primary reason for the failure. I have no idea how long it has been missing, but accidentally noticed the absence of the shim a week or two ago.
Moral of the story: Always re-check the torque on those U-bolts!
