LED light for gauge cluster
dblupcobb
Pensacola
I recently installed the LED background light kit available on JBG. For those not familiar, the luminescent panels mount on top of the original gauges. The kit comes w/ a power converter that you can either run power to remotely or you can tie it into your original gauge lights. I chose to tie it into one of my gauge lights since I would no longer be needing them so the instrument lights would illuminate when I turn my headlight switch on. The lights looked great when I first installed them and put the gauge cluster back in my dash. However, they shorted out for some reason when I adjusted the LED color control? I have tried wiring the power source to one of the other gauge lights, but none of the 3 not in use work now. Is there a fuse that might have blown controlling my gauge lights? I have changed all the fuses in the glovebox, but do not think they control these lights? Could it be something in my headlight switch (the headlights work)? Has anyone else installed this kit? How did you wire it?
Viperwolf1
electron whisperer
Turn the headlight switch knob to control the voltage to the dash lights. If the voltage to the LED's gets too low they don't workie.
D
dblupcobb
Pensacola
Thanks for the tip. I checked to make sure that the headlight switch dimmer was turned all way to just before it clicks over to illuminate interior light and it is, but still no LED. I also clicked it over to engage the interior light, and still nothing. None of the lights I pulled out of the gauges are illuminating either. Do you have any other suggestions?
Tedster100
Chairman of the Bored
It's been some time since I installed mine but I don't recall anything in the destructions saying that you could run without the power supply, in fact, mine came with a dimmer as well as a switch to change from blue to green. Installed over a year ago and just finally wired the new Centech harness and it works just like it should but it's not tied to the dash lights at all (it is switched off of the ignition). Maybe put the power supply back?
D
dblupcobb
Pensacola
Mine has the same kit, maybe I misunderstood the instructions for installation. There are two wires coming off the power source. I hooked one of these into one of the wires coming off an unused gauge light, and the other to ground. Where did you wire yours if it is hooked into the ignition?
Tedster100
I installed a new Centech harness, it was a pain but worth it. It allows for accessories with a constant power and key'd power spares. You should be able to tap into a key'd power somewhere behind the dash, radio power maybe?
D
dblupcobb
Pensacola
I finally have them working now. I wired them directly to my tach power so when I turn the key, they come on and stay on. Something must have shorted somewhere when I wired them previously, because since then, all my dash lights, gauge lights, and even tach light that used to illuminate when pulling the headlight knob are all out still.
Oh well, I can see my gauge cluster at least.
Thanks for your help.
Bronchole
Chatsworth, Ca (LA)
If you have an aftermarket wire harness check to see if there is a seperate fuse in the wire harness from the headlight switch for the dash lights, I seem to remember seeing an in-line fuse holder on some of the harness conversions.
