All my lights work besides the blinker/brake on driver side. The tail light works when headlights on and all other lights/ blinkers work. Where should I look to fix this?(My Bronco is a 1977)
I assume you tried replacing the bulb? How does it work with the hazard flashers? Turn signal switch might be a problem if the bulb works with the hazards. If not the problem is somewhere in the yellow-black wire between the steering column and bulb. A lot of early Broncos had dual exhaust at some time in their lives and that tended to melt the insulation on the stock wiring harness going to the rear lights.
I also ran a wire from the switch to the yellow-black wire that connected to the tail light and got nothing so does that mean the tail light wire is bad?
