noreasteb
Ok, here's my dilemma... i just installed a WH 1" complete body lift/mount kit before placing my tub back on the frame. Now that the tub is set, the steering shaft is at least 2" too short. I figured I could just move the shaft to the outer limits of the splines on both the steering box and the end of the column, but this thing isn't even close.
Would it be possible or safe to cut the lower shaft and sleeve it with a thick walled pipe then weld and/or through-bolt both ends to lengthen the shaft?
As many of you are, I to am really tight on $$ and cannot really afford a new custom lower shaft. Any other recommendations would be helpful as well.
