- May 29, 2006
- 2,773
BC's tanks have been "sliders" for quite some time .
I put mine in about five years ago , it was USED then , so they may have always been sliders.
Be sure to check the fit (float height) of the sending units on the 23 gallon tanks. Some older ones would show empty when there was 8 gallons left , which gets really frustrating because the last 1/3 of the tank , you are guessing when you will run out ... or you fill up every 16 gallons , which isn't much better than the stock tank.
Either get a proper sending unit for the tank or just bend the float arm down till it is much closer to the bottom of the tank at rest. This means that the gauge will stay at FULL for a long time before it moves ,but at least you know where Empty is.
