semprbronc
I am almost done my engine rebuild, so close to turning the key I can't stand it. This board has been a tremendous resource for information and suggestions. Thank you all! Knowing answers were only a mouse click away gave me great confidence to do this. I have also learned quite a few lessons through trial and error over the last month. I thought I'd share some:<br>1.Haynes sucks 2.When seperating the tranny from the xfer case, there are 13 bearings waiting to fall into the case,gravel drive,or parts washer. That was a fun afternoon. 3.When pulling the engine/tranny/adapter the way haynes describes, don't forget the shifter, it WILL get stuck. 4.Haynes sucks 5.Drain the oil before removing the engine, or have lots of kitty litter available. 6.When ordering a $349.00 rebuild kit, don't assume $500.00 will cover everything. $1100.00 and counting...God bless overtime. 7.Haynes sucks. 8.When putting the tranny back in, don't do it w/xfer case attached and a standard floor jack. It is almost impossible to maneuver into place without dropping it at least once. I miss my thumb nail...And the cross member is another lesson in patience. 9.Don't put the engine in w/torque converter attached. It will have to be pulled out again. 10.Haynes sucks. 11.When shoe horning the engine in for the second time, don't forget the plate that goes between the engine and tranny. You know the one, It goes BEHIND the flywheel. 12.When shoving the engine in for the third time, make sure all loose plugs are clear of the engine. It was fun hunting for the connector that went to the tranny wiring. It was wedged between the engine and firewall. 13.Did I mention that Haynes sucks? All in all though, it has been great. Many hours of bonding for myself, my father, and my sons. Wouldn't have changed any of it.(except maybe putting the motor in 3 times :-[) Thanks for letting me share, and if you have any other interesting lessons learned, I'd love to hear them.
