Let's see some Tow Bar set ups.
cactushorse
I'd like to get a tow bar for the Bronc any advice and or pics would help. Some fab work wont be a problem .THX
Baja71
Let me be the first.
broncnaz
If I was home I'd get some pic's of the one we built for my 73. Its mounted between the frame rails behind the front bumper and drops down under it made it out of 1/4" OR 3/8" plate steel and some angle Iron barely noticeable and provides a good pull point if I ever need one.
C
cactushorse
I would like to see that. Post some pics when you have time. Baja, that looks like a clean set up but the pic is to small for detail.
yak67
in case anyone wants one, I have one I'd sell, never even pulled with it, the brackets are on my bumper, but other than that it is brand new. PM me if you're interested.
broncnaz
I'll see if I have any pics on my lap top that show it they wont show everything but might give you a idea its all I got right now I'm 8,000 miles from my bronco right now
Ryans71
Milton, Wa
Here's a pic of mine.........
C
cactushorse
So far they look like i expected (lots of different styles) Seems like it should be designed to be as flat as possible. Keep 'em coming if you have them.
sevenTseven
Oklahoma City, OK
You can see the homemade job that was on mine when I bought it in my gallery. While the towbar itself was of questionable quality, the mounting system was pretty spiffy.
The towbar itself fits between the 2 tabs, then a pipe with 1 large end slides through the the first tab, through the towbar, then out the other tab. The pipe was then secured by a bolt on the small end, it made removal very easy. When its off all thats left is the 2 tabs which could be used for D rings or anything.
Baja71
This might be better.
C
cactushorse
I read that thread Lonesouth, looks like the jury is in favor of both! But it was some good info.
rednck21
%) no thanks, ill stick with the trailer also...
texastreasures
Homemade Bumper With Towbar
Friend of mine would use this bronco to fix fences at the ranch He had a miller welder mouted in the bed and would pull behind his truck to transport no problem.
