lift blocks
bronco stuff
I want a 2'' lift , Ill put new coil springs in the front, and just blocks under the rear,, can anybody tell me what size the blocks are, also what size is the pin ? I know they sell them but I work in a machine shop and I can just make'em.
Thank you
strider
Holland
I can't help with dimensions, but I can recommend that you make them wide enough so the u-bolts go through them. This eliminates any chance for them to squirt out if a u-bolt loosens up. I chose to run a 5/8" ballnose cutter down the sides of mine to make the path for them. I built the wedge into mine to rotate the pinion up as well.
I'm surprised that nobody has started screaming about you not just putting springs under it. I guess that speaks to the maturity and experience on this board compared to so many others.
bmc69
Heck..properly designed blocks as tall as 4" came on some model trucks from the factory.
Seriously like that machining detail that captures the blocks with the u-bolts. Nice touch.
dixieboyz13
Johns Island
Whatever you do, dont buy the cheap aluminum ones from the auto parts store. Had a bad experience with them cracking. I have a set of 3" cast blocks with the angle built in. I can try and get you some measurements, and then you just take an inch off each end.
The springs and perches are approximately 2.25" wide, so anything in the 2.5" area and wider would allow you to notch it for the u-bolts. That's what I did when I put 1" blocks in mine years ago.
I've seen them where they were completely captured, like I think strider was mentioning as well.
But a simple notch to help locate/retain them would still be a helpful extra safety feature for normal use.
Figure on at least 9/16" u-bolts, which is an upgrade from stock as well. Might as well make things stronger while you're in there, right?
I forget what the hole in the perch is, but is's something like 7/16-1/2 inch. Someone can probably get you an exact measurement.
I think we have people open theirs up to 9/16" when installing our springs, due to the larger centerpins in the packs.
bmc69
Pretty sure that the spring center holes are either 3/8" or 7/16"...the latter being the size that people like me open them up to if they came with the former. That said..I don't know what the head diameter is and its that size you need if fabbing blocks;
broncnaz
Depending on the stance you want and how much your current springs have sagged you may need more than 2in blocks. kinda need to install the front springs first then I would take some measurements from the ground to say bottom of the frame near the rear axle spring mount then jack up the truck from the bumper until you get the stance you want then measure again. The differance should be your needed block height. You may also consider checking your pinion angle while at that height as you could build a taper into the block and set the pinion angle at where it needs to be.
Just hit the junkyard for full size ford trucks with factory blocks and get those. Mill angle as needed.
Pa PITT
Stephenville TEXAS
... Dorman sells those spring center bolts .. If my memory serves me correct the no. is like 220-660 or 212-*** ... Who know I guess but you can go to a parts house and get a 7/16 spring center bolt and then you've got the info you need. Oh don't worry about how long they are .. you do cut them off .. You may throw away 6 inches so do get hipper.
