Lokar Flexible Engine Dipstick ??'s
bob_lafrentz
Cody, WY
Hi all,
I recently called Lokar about a flexible engine dipstick. I have the original 1969 302 oil pan with the push in dipstick. They said I needed part number ED5013 and so I purchased it.
The bottom 1/2 of it should push into my oilpan. But, just above the 1/2 mark, the push in ferral gets larger in diameter and has two rubber O-rings imbedded in it. It makes sense that these should push into the oil pan and create an oil-tight seal. But, the diameter of the ferral at this point is too large.
So, my question is this: Is this the model number you used and if so, did you just push it in as far as you could and then sealed it with silicone rubber?
Thanks.
OK downloaded the Lokar catalog http://www.lokar.com/pdf/lokar-catalog16.pdf page 55 has the dipsticks.
Apparently Lokar is not that knoweledgable about fords. The best I can deduce is that the dipstick in question is for an '81 (or there about) up block that uses a dipstick in the block on the drivers side just above the oil pan rail.
The Bronco is an oddball if you didn't know by now. The dipstick is on the passenger side, in the pan and is either a press fit or screws in.
The best I can figure is that Lokar gave you bad advice.
