Bronco will be used for mild trails and street. I think i have talked myself out of column shift, like the clean install of the no column, plus not having to deal with the indicator for the overdrive. The winter seems to be not so clean of install as the lokar? what is the general consensus. I am buttoning up the frame so i need to make sure everything that can be done while body is off is done. Am i thinking clearly here on getting away from the column?
