Justafordguy
- Sep 26, 2009
- 6,253
If the pedal is soft but not low I bet it still has air in it somewhere.
for nearly 5,000 posts, you would think I should have a nicer bronco.
so, here is a fun fact. Nearly everything in the rear drums is identical, side to side. The one thing that is specific to each side? The auto adjusters. Put those on the wrong side, and it will auto adjust the rear brakes to nothing.
I found that after I replaced the master cylinder, but as cheap as the MC was, I'll keep it. The old one looked like it may have been leaking into the booster. No a lot, but enough to leave a gunky film.
I think it is time to take the top off. Maybe this weekend.
Hey Parker your bronco did great at sowega but I think you needed them ditch witch tires on that one hill!;D
The one next to the highway overpass, had to come up it to get down to the concrete spillway.
I guess I would have had to go up it then. I must have picked a better line because I don't remember it being a problem.
It was not too far from us reaching the hole that got you last year. At the bottom of it was a bit of wetness to load up the tires with mud. I had the tires smoking on the roots my last try up while sawing the wheel a bit. Got close but no cigar!
there was another line that most of us took. It was to the right, and Brian had to hold a small tree back
