Back on the bumper caps.
I found some sheet metal in the shed from which I was able to make some end caps. I used a roll of teflon tape to mark out 4 ~2" circles and used some tin snips to cut them out. Not sure what the thickness was, maybe 20ga, the snips cut with ease. I think that is part of what made this the hardest, most annoying, attempt at welding so far.
The tube is 3/16 if not 1/4 wall. It was nigh impossible to get the caps welded on without burning straight through the cap. My settings were 1/40 and .23 wire, 100% CO2. I suspect I would have had an easier go of it with a thicker cap, but either I wasn't getting enough heat into the pipe, or too much into the cap and blowing through.
I finally got all 4 welded in, I made at least 4 trips back and forth on each piece between the welder and the grinder. I would weld it all up, think it looked OK, then after grinding I would see the crack where there was no penetration to the pipe. Extremely frustrating. I'll post pics tomorrow.
