Longer gas filler neck?
SteveL
Huge chevy guy
Hawthorne ca
They don't make longer filler necks that I know of but you can buy a longer connecting hose. Napa sells it by the inch but it ain't cheap.
Speedrdr
Legend in my own mind
Paris, MS
I’m thinking he is meaning that he wants to shorten the circled filler neck. But I have been wrong already today, so there’s that.
Randy
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Factory filler neck has a flange that goes against the inside of the fender, 3 screws from outside attach it.
Must be an aftermarket aux tank installation.
Use a bronco filler neck. 2 versions for the vented and non-vented gas caps you probably have a junkyard special now. So the aux tank is likely a retrofit, maybe a repair. Don't be surprised if it isn't a match for your year.
nickeboy
nickeboy
YA, I've never seen anything like it. I'm hoping when I remove it, I can bolt up an OEM version. Has anyone ever experienced this?
spap
Maybe the hose is just too long and you can cut it down. Somebody found a hose and just stuck it on there
The thing is we don't know what parts you have. We know what a stock Bronco filler neck should look like, and that isn't it. Outside of that it is just guesses and assumptions.
nickeboy
nickeboy
Yep, Just seeing if anyone has come across this before. At worst, I will replace the quarter panel.
